It is currently Sun May 18, 2025 3:48 am
 Page 1 of 1 [ 5 posts ]
 Post subject: Headlight washers
PostPosted: Fri Mar 23, 2007 1:31 am
I notice they are quite common outside of the UK.
Just wondering a couple of things. Do they pop out of the bumper when activated, much like those on mk2 Xantias? Also do they use a seperate fluid bottle? If so where is it located?
PostPosted: Fri Mar 23, 2007 3:34 pm
WAT DO U WANT THEM FOR JUST CLEAN THEM WITH A SPONGE AND WATER. :?:i didint mean no harm rossy boy.and im rubbish on computer and forgot cap were on not that it means anything to me bit blind so ther easier to read wen i dnt have glasses on.soz :? :? :?
 Post subject: Re: Headlight washers
PostPosted: Fri Mar 23, 2007 7:30 pm
Comeone thats not whay he's asking.. and check your capslock plz!
They dont pop, they just sit there. It has a separate tank and pump, tank is quite big and located in front of the front right tire (if you dont have the thank you'll see a hole where the filler neck should be).
PostPosted: Fri Mar 23, 2007 8:40 pm
bye bye then will speak no mre i quit.
PostPosted: Fri Mar 23, 2007 11:51 pm
aaah yeh, I wonder (out loud) if the tank is the same as that on Peugeot's 106 (for its windscreen jets) - hence the size - its located in front of the front wheel. Would make sense, 1 tank multipul uses mmmmm *scratches chin*
