Headlight washers http://zx16v.net/forum/viewtopic.php?f=1&t=318 |
Page 1 of 1 |
Author: | Ross [ Fri Mar 23, 2007 1:31 am ] |
Post subject: | Headlight washers |
I notice they are quite common outside of the UK. Just wondering a couple of things. Do they pop out of the bumper when activated, much like those on mk2 Xantias? Also do they use a seperate fluid bottle? If so where is it located? |
Author: | dugy cam [ Fri Mar 23, 2007 3:34 pm ] |
Post subject: | |
WAT DO U WANT THEM FOR JUST CLEAN THEM WITH A SPONGE AND WATER. ![]() ![]() ![]() ![]() |
Author: | ZX-Cruiser [ Fri Mar 23, 2007 7:30 pm ] |
Post subject: | Re: Headlight washers |
Comeone thats not whay he's asking.. and check your capslock plz! Ross wrote: I notice they are quite common outside of the UK.
Just wondering a couple of things. Do they pop out of the bumper when activated, much like those on mk2 Xantias? Also do they use a seperate fluid bottle? If so where is it located? They dont pop, they just sit there. It has a separate tank and pump, tank is quite big and located in front of the front right tire (if you dont have the thank you'll see a hole where the filler neck should be). |
Author: | dugy cam [ Fri Mar 23, 2007 8:40 pm ] |
Post subject: | |
bye bye then will speak no mre i quit. |
Author: | Ross [ Fri Mar 23, 2007 11:51 pm ] |
Post subject: | |
aaah yeh, I wonder (out loud) if the tank is the same as that on Peugeot's 106 (for its windscreen jets) - hence the size - its located in front of the front wheel. Would make sense, 1 tank multipul uses mmmmm *scratches chin* |
Page 1 of 1 | All times are UTC + 2 hours |
