It is currently Sat May 17, 2025 3:29 pm
 Page 1 of 1 [ 10 posts ]
 Post subject: HOW MUCH !!!
PostPosted: Wed Aug 22, 2012 5:18 pm
I've got to remove the wheel arches and the sill trims/skirts on the Zx in the next few weeks to treat some very minor surface rust and then treat the underbody with some bilt hamber products . I went to the dealer yesterday to check on availability & prices . The clips for the arches are only 32p each so I ordered 20 , the clips for the side skirts were £1.72 EACH + vat , I ordered 15 of these and a new dipstick too which was a bargain at £10.26 . The grand total £50.95 for not alot really , but if it keeps the old girl on the road it's gotta be worth it .
 Post subject: Re: HOW MUCH !!!
PostPosted: Thu Aug 23, 2012 2:02 pm
Hi Mark,
Do you have the parts number for theese clips ?
eagle
PostPosted: Thu Aug 23, 2012 8:16 pm
hi mark,
do you also have the part no. for the dipstick?
cheers paul
PostPosted: Thu Aug 23, 2012 8:51 pm
The part numbers are .
95637052 for the skirt clips £1.72+vat each (packs of 5 only)
6991N4 for the wheel arch clips £0.32p+vat each (packs of 5)
117418 Dipstick £10.26 + vat
There are 18 skirt sill clips on the Zx16v .
These are the part numbers on my invoice , there is also a bin number ? If this is required .
I did think myself that the clips we no longer available , I'll find out how many they have available when I collect mine tommorrow . I would imagine that the original clips break on removal ? I've never took an arch/sill off .
PostPosted: Fri Aug 24, 2012 7:31 pm
thanks for the info mark and yeah i bet you break quite a few when your changing them over i remember taking a body kit off an AX and they are really brittle so best of luck let us know how you get on !
cheers Paul
PostPosted: Fri Aug 24, 2012 8:21 pm
Will do . It might be a few weeks yet as I'm going to a Citroen show in a couple of weeks and I want everything intact :-)
PostPosted: Sun Aug 26, 2012 2:16 pm
James here's the pics of the clips the first ones are for the arches
These ones are for the sill/skirt trim BUT since talking to you earlier I have prized a section of my sill trim away and found that these are for the bottom of the sill and there is a completly different clip for the top section
These are secured to the car by a screw which will more than likely need drilling out .
Here are the other sill clips which are also required ( do you know how many ? )
I will call at the dealer on Tuesday and find out if they are still available .
PostPosted: Sun Aug 26, 2012 9:05 pm
Thanks Mark,
Great pictures and info, i will try to order some from my local dealer.
eagle
PostPosted: Sun Aug 26, 2012 10:33 pm
Glad to be of help , I'll find out on Tuesday about the availability of the other clips required .
PostPosted: Tue Aug 28, 2012 6:42 pm
I called at the Citroen dealer today and was told that these clips are no longer available sad
I tried a pug dealer and they said the same , so I shall try and locate an alternative fixing .
Users browsing this forum: No registered users and 8 guests
