It is currently Sat May 17, 2025 8:42 pm
 Page 1 of 1 [ 11 posts ]
 Post subject: zx16v - second Ignition coil die in a month
PostPosted: Mon Jun 25, 2007 7:58 am
Hi
about 3-4 week ago 1 ignition coil failed, i replaced it, today another one die :?
is it just a coincidence or maybe something cause the coils to fail, what could it be? :roll:
PostPosted: Mon Jun 25, 2007 10:25 am
they are all the same age so if one has failed i would expect them all to be getting old and replace them all especially seeing as they are not that expensive
187 bhp and rising !
PostPosted: Mon Jun 25, 2007 12:33 pm
in Israel they are a little expensive
how much cost one coil in england?
PostPosted: Mon Jun 25, 2007 2:03 pm
I'd only replace the broken ones, €70 is not really cheap, €280 is even more :shock:
It's an easy job so that's not a problem.
PostPosted: Mon Jun 25, 2007 2:35 pm
about 50 pound i paid for one.yeah dont like the heat.but that all i need so 50 aint to bad.if it get ur lovely car going again
PostPosted: Wed Jul 04, 2007 8:50 am
I had a spark plug lead (ignition coil) breakdown and so it ran on only 3 cylinders until the fault was diagnosed. Since then it has been running very well.
However since the lead changes the car has been developing a similar problem (intermittent) as before. Although the sparks were changed at the same time the car sometimes losses power, sounds like a boxer engine and then runs okay again. Very Odd. Can anybody shed any light if this is common problem, if the leads/ignition coil are unreliable, distributor problems, injectors etc.
Thnaks
PostPosted: Wed Jul 04, 2007 8:57 am
I ask my mechanic and he said that maybe the ignition module killing the coils
There are 2 modules how can i know which one connect to which coils?
PostPosted: Wed Jul 04, 2007 10:07 pm
Check the schematics, if you have them.
PostPosted: Thu Jul 05, 2007 7:39 am
I checked it, it's not the module (the 2 coil that broke down connected to different coil)
one module connect to the coils on cylinder 1 and 3
and one module connect to the coils on cylinder 2 and 4
I replaced the spark plugs, hope it will be ok
PostPosted: Thu Jul 05, 2007 6:48 pm
Ok.
I've heard this before, if one dies chances are another one follows rapidly.
But I only replace them when they are really broken.
PostPosted: Mon Jul 09, 2007 3:26 am
Balong,
Clean the contacts on the ignition modules first...if problem still persists, then it could be one of coils which are almost dead...tony has some spare coils to sell...
With Rgds,
Max16V
1995 ZX 16V
Users browsing this forum: No registered users and 5 guests
