It is currently Sat May 17, 2025 8:48 pm
 Page 1 of 1 [ 10 posts ]
 Post subject: Engine hunting on tickover
PostPosted: Fri May 23, 2008 6:28 pm
What can cause this on my phase 1?
PostPosted: Fri May 23, 2008 8:08 pm
What do you mean :?: Hunting on tickover... tickover is cranking I guess? but hunting?
PostPosted: Fri May 23, 2008 11:27 pm
when idle, when the engine is running but the throttle is not pressed. my engine increases and decreases its speed.
PostPosted: Sat May 24, 2008 8:54 am
Maybe you idle airflow actuator is not quite working as it should. You cab try to clean it a bit.
PostPosted: Wed May 28, 2008 9:43 pm
+1 ;)
otherwise it must change ... ~150 € at citroen in france ...
PostPosted: Wed May 28, 2008 9:51 pm
It's in lots of PSA cars like the XM, 306, etc. Take a look at a local scrappy and you'll save some €€€€'s.
PostPosted: Fri May 30, 2008 1:41 am
is this the idle thing u have put a filter on and connected to the main intake?
PostPosted: Fri May 30, 2008 2:48 pm
That's right dugy.
PostPosted: Wed Aug 13, 2008 6:33 pm
Hi,
I had the same problem when I first got mine. After a lot of head scratching it turned out to be a small split in one of the AVAC pipes that was very hard to see / find. Would sugest checking them from start to end, if they look old and worn replace them anyway, you can buy a length of the pipe for a few quid. Hope this helps.
Cheers
PostPosted: Wed Aug 27, 2008 12:38 am
Yep it was the vac pipe going to the ecu, was split and not secured correctly. fixed it and she now runs great! thanks for your posts!
Users browsing this forum: No registered users and 5 guests
