It is currently Sun May 18, 2025 5:05 am
 Page 1 of 1 [ 10 posts ]
 Post subject: Engine hunting on tickover
PostPosted: Fri May 23, 2008 6:28 pm
What can cause this on my phase 1?
PostPosted: Fri May 23, 2008 8:08 pm
What do you mean :?: Hunting on tickover... tickover is cranking I guess? but hunting?
PostPosted: Fri May 23, 2008 11:27 pm
when idle, when the engine is running but the throttle is not pressed. my engine increases and decreases its speed.
PostPosted: Sat May 24, 2008 8:54 am
Maybe you idle airflow actuator is not quite working as it should. You cab try to clean it a bit.
PostPosted: Wed May 28, 2008 9:43 pm
+1 ;)
otherwise it must change ... ~150 € at citroen in france ...
PostPosted: Wed May 28, 2008 9:51 pm
It's in lots of PSA cars like the XM, 306, etc. Take a look at a local scrappy and you'll save some €€€€'s.
PostPosted: Fri May 30, 2008 1:41 am
is this the idle thing u have put a filter on and connected to the main intake?
PostPosted: Fri May 30, 2008 2:48 pm
That's right dugy.
PostPosted: Wed Aug 13, 2008 6:33 pm
Hi,
I had the same problem when I first got mine. After a lot of head scratching it turned out to be a small split in one of the AVAC pipes that was very hard to see / find. Would sugest checking them from start to end, if they look old and worn replace them anyway, you can buy a length of the pipe for a few quid. Hope this helps.
PostPosted: Wed Aug 27, 2008 12:38 am
Yep it was the vac pipe going to the ecu, was split and not secured correctly. fixed it and she now runs great! thanks for your posts!
