It is currently Sat Nov 30, 2024 8:32 am
Post subject: engine swap Posted: Sun Oct 02, 2011 9:15 pm |
just out of intrest how hard in wat is need to swap the gti-6 engine in to the zx with the s16 engine i dont want it done just out of intrest
Post subject: Re: engine swap Posted: Sun Oct 02, 2011 10:02 pm |
Welshpugs your man Dugy , I'm sure he'll be along soon
Post subject: Re: engine swap Posted: Mon Oct 03, 2011 6:09 pm |
XU10J4RS engine loom attaching to the ZX plugs, all the RS coolant pipes, the RS long gear rod from the bottom of the stick to the subframe, the RS cat, RS radiator, RS air intake pipe from Airbox to throttle body, RS Battery/ECU box.
ECU will need to be unlocked as the ZX never used a transponder immobiliser.
Use the original sump (or cut the a/c pump brackets off the alloy RS sump) alternator bracket PAS pump and pas pipework, original air box.
Clutch is the same, just keep the 5 speed gearbox.
Pretty damn easy conversion tbh :D
exhaust wise the centre and rear box is the same as used on the RS enghined ZX's, phase 1 Xsara will fit, Phase 2 will fit with an extension of the centre pipe.
Post subject: Re: engine swap Posted: Mon Oct 03, 2011 7:44 pm |
cheers for that just information to store in the brain not that i was planing it just maybe a future thing since my engine is getting oldish
