It is currently Tue Apr 22, 2025 12:21 am
 Page 1 of 1 [ 3 posts ]
 Post subject: Seems flat low down in revs
PostPosted: Thu May 28, 2015 11:49 pm
Hi wondering if anyone has had this problem with there 16v recently I've noticed my car seems to be low on power low down up to about 4000 rpm as a little hesitant but does run fine. Has anyone got any advise thanks
 Post subject: Re: Seems flat low down in revs
PostPosted: Fri Jun 05, 2015 3:55 pm
Problem FIXED! It was a fault with acav my inlet flaps wasn't moving fault turned out to be with the T piece in the vac pump and has some sort of one way valve in it and that's where the vacuum comes from to operate the system.
PostPosted: Wed Mar 30, 2016 7:18 pm
That piece is usually the most reliable part of the ACAV system, apart from breaking off the thin pipe yourself when removing it.
Users browsing this forum: No registered users and 1 guest
