It is currently Wed Dec 04, 2024 5:35 am
jaredboy
Post subject: My Citroen ZX 16v Posted: Fri Mar 21, 2008 1:52 pm |
Joined: Mon Jan 22, 2007 1:20 pm Posts: 25 Location: Norway
Hi my name is Jared and I'm from Norway, this is my Citroen ZX 16v.
When i first bought it.
Work done to it so far:
-New Head gasket
-New water pump
-New cam belt
-New wishbones
-New front arb mounts
-New Drop links
-New Rear beam
-Gr.N engine mounts
-New Battery
-AVO Coilovers
-AVO rear shocks
-Godridge Brake lines
-GTI6 inlet
-PTFE inlet gasket
-Mi16 injectors
plus much more!
Some pictures:
The next thing to do is fix the exhaust system, before "mot" here i Norway.
Just waiting for summer, and some hot weather.
_________________ Citroƫn ZX 16V
Peugeot 309 T16
pepezx
Post subject: Posted: Fri Mar 21, 2008 3:09 pm |
Joined: Fri Oct 20, 2006 5:00 pm Posts: 61 Location: Czech Republic
nice zx, silver is the best of
what upgrade on motor do you have please??
_________________ Citroen ZX 2.0 16V crashed
Citroen ZX 1.4 reflex
Czech Republic www.zx-club.cz
http://pepeeee.blog.cz/
Post subject: Posted: Sat Mar 22, 2008 12:18 am |
jaredboy
Post subject: Posted: Mon Mar 24, 2008 10:45 pm |
pepezx wrote: nice zx, silver is the best of what upgrade on motor do you have please??
Yeah, silver suits the car! Need removing some dents, and a respray thought, a bit shabby at the moment.
Haven't done too much with the engine so far, I've changed the inlet manifold to a gti6 item and put on some 1.9Mi16 injectors for a bit more fuel.
Also working on a enclosed air filter, right know i have a open raid filter.
New engine coming next year. it will be a beast
Peugeot 309 T16
jaredboy
Post subject: Posted: Mon Mar 24, 2008 10:47 pm |
ZX-Cruiser wrote: Nice droplinks!!
They are really good! Works a treat on my lowered car.
Peugeot 309 T16
pepezx
Post subject: Posted: Mon Mar 24, 2008 11:59 pm |
And GTI6 maniford is better then ACAV??
jaredboy
Post subject: Posted: Tue Mar 25, 2008 12:19 am |
pepezx wrote: And GTI6 maniford is better then ACAV??
Well, i do think so.
For a starter my vacuum clocks didn't work, so needed sorting out anyway. And you get a much bigger throttle body, and longer runners.
From the little i have driven the car, I've lost some low rev torque but gained a lot more inn the top end of the rpm scale. Now it really comes alive above 6000rpm.
But i do have a flat spot at about 4000rpm, not a big problem. But that'll be fixed when the new engine management system will be installed.
Peugeot 309 T16
Post subject: Posted: Sat Mar 29, 2008 4:33 am |
Congratulations, Jaredboy! nice work on your ZX!
you have bought some parts from the people of the 306GTI6.com forum (droplinks, ptfe gasket)?
what is your impression about these mods:
-Gr.N engine mounts
-PTFE inlet gasket
Greetings from Brazil
_________________ Citroƫn ZX 2.0 16V Dakar spec CarDomain site Special Cars site
jaredboy
Post subject: Posted: Sun Mar 30, 2008 8:10 pm |
edsonmassao wrote: Congratulations, Jaredboy! nice work on your ZX! you have bought some parts from the people of the 306GTI6.com forum (droplinks, ptfe gasket)? what is your impression about these mods: -Gr.N engine mounts -Godridge Brake lines -PTFE inlet gasket Greetings from Brazil
Thanks Edsonmasso!
Yeah, i have bought some parts from the 306gti6 forum, the items have been really nice made so far.
Well impressed!
The Godridge hoses have made the brake pedal a bit harder, and thats a good thing. But haven't tried them that much, since am not using the car right now.
The PTFE gasket really made the inlet manifold cooler, but as the weather gets hotter her i guess i'll make it even more noticeable.
I'm going to England next week to pick up some more parts from a 306gti6 forum member, really looking forward to it
Have anyone tried GAZ shocks on there ZX? I think ill change the AVO's to GAZ. The Avo's have been a bit hard, making the ride harsh, and not suited for road use.
Peugeot 309 T16
jaredboy
Post subject: Posted: Sun Apr 06, 2008 5:45 pm |
I had a little trip to England, and got me some new parts this weekend!
This is a kit made by a member on the 306gti6 forum. I'm really impressed by the kit, the engineering and design is perfect!
Just need to pick up the T16 engine, buy some rods, pistons, intercooler, injectors and make a new loom.
I'll probably wait till next year with the new engine install, since I've got a lot of other things that need attention on the car.
More updates coming soon!
Peugeot 309 T16
RG192
Post subject: Posted: Wed Apr 30, 2008 7:57 pm |
very nice !
are expected later!
Post subject: Posted: Fri May 02, 2008 1:18 am |
jaredboy
Post subject: Posted: Thu May 29, 2008 9:45 pm |
Been a while since my last update.
The car is really good to drive, and its fast, but getting a bit to much fuel with the mi16 injectors at lower revs.
Got the new GAZ coilover kit the other day, these do have TUV papers so will be approved to use her in Norway.
The car as it is now has AVO front coilovers and Koni rear shocks and I'm well pleased with them.
So will be nice to feel the difference between them.
These are the new front wishbone mounts, hopefully they will tighten up the front feel of the car.
And should last a lot longer then the original items.
Here are some pictures of the car, lowered a bit but not as much as "pepezx" 16v
And some pictures of the engine bay, done some more mods after i took the picture, made a ECU bracket and mounted a Catch tank since it spitting some oil.
I've made a new exhaust system too, but ill take pictures of that later.
Peugeot 309 T16
Post subject: Posted: Fri May 30, 2008 1:37 am |
nice looking engine bay nice with the matching silver.a supercharger is it.an expensive bit of kit?intresting stuff u butin it in the zx
Post subject: Posted: Fri May 30, 2008 4:37 pm |
