It is currently Mon Dec 02, 2024 10:33 am
dugy cam
Post subject: Posted: Thu Dec 18, 2008 7:40 pm |
Joined: Thu Feb 15, 2007 10:11 pm Posts: 391 Location: SCOTLAND
hahaha all takes time n it all hard to find time u will get ther in the end it wat i say to myself one day i will get ther looking good though n clean
_________________ 16V DAKAR AND WIDEARCHED 16v got another i love them
Post subject: Re: My new Citroen ZX 16V Posted: Sat May 09, 2009 7:43 pm |
Time for a update! After my daily 16V died on me, I temporarily had a Nissan Sunny to my disposal. But being a complete 16V addict, I bought myself another one It was really cheap, but there had to be done quite some work to get this car back in to good condition...and just for fun I lowered it a bit. From the top of my head. -Rear axle replaced -1 coil -2 rimms+tyres -dampers incl new topmounts etc -H&R lowering springs -replaced dash -replaced steering wheel -exhaust from manifold to end muffler -rear discs/pads + calipers + handbrakecables -radiator -Complete ACAV except for manifold The result: Car is lowered front + rear about 2cm, it's hardly noticeable looking at the photo though. But this topic was about my turbo project! I created a exhaust form turbo to the end and modified the wiring loom. It is supposed to be driveable at the end of july. Couple of pics. I don't have a endtip, so just used a 1 meter pipe as reference
kentuequi
Post subject: Re: My new Citroen ZX 16V Posted: Tue May 19, 2009 9:58 am |
It is the red one which died?
If it is, too bas you'ne not living in France! I'm looking for a Red right door, but I can't find one...
Nice work for the other one!
It's seems that there's a lot of 16V in Holland, I am wrong?
_________________ Got a ZX 16V ACAV, and I'm lovin' it!
RG192
Post subject: Re: My new Citroen ZX 16V Posted: Fri May 22, 2009 7:35 pm |
Joined: Tue Jan 08, 2008 2:55 am Posts: 73 Location: paris (france)
kentuequi wrote: It is the red one which died?
It's seems that there's a lot of 16V in Holland, I am wrong? seeks better
kentuequi
Post subject: Re: My new Citroen ZX 16V Posted: Fri May 22, 2009 8:23 pm |
I'm only searching on Ebay and leboncoin but everytime the car is sold in one piece... If you find some, tell me!
Post subject: Re: My new Citroen ZX 16V Posted: Tue Aug 18, 2009 9:00 pm |
It also has a new MOT and is back on the streets again Modification list so far: XU10J2TE Garret T3(Saab) QSP piston BOV Group N engine mount set Spal ventilator XM rad + intercooler + coolant reservoir XU10J4 oil heat exchanger Powersprint catalytic convertor, Simons pipes and end muffler with Volvo 850 T5 tailpipe(all custom made), manifold made by someone else though Xsara VTS 283mm brake conversion Koni yeollw shocks with H&R springs Phase2 alloys Batterie in the boot
Post subject: Re: My new Citroen ZX 16V Posted: Fri Dec 25, 2009 5:11 pm |
After some electrical problems, which prevented full boost, the car drives pretty well and even at orignal boost feels pretty quick. Compared to a 180hp RFS ZX engine it pulls already better from 140 tot 175. I have bought serveral upgrade parts which still have to be installed. When I have upgraded the intercooler, I'm going to up the boost to about 0,95bar, hopefully I will hit the 190+ HP. The biggest news however... I will be stripping and complete rebuilding 2 ZX 16V's together with another forum member. One with the RFS engine build up with group A specs and one turbo one, I however don't have decided if I will keep using the tct engine or are going to build a RFY one...
jaimieberkhout
Post subject: Re: My new Citroen ZX 16V Posted: Sun Dec 27, 2009 10:15 pm |
Joined: Thu Jan 15, 2009 6:51 pm Posts: 566 Location: Amsterdam
I drive in it. Its a realy nice car. and i had a lot of fun to drive it. When the ingene pas the 3000 rpm the car accelerates realy fast now up to 1 bar boost And the whole car overhaul
dugy cam
Post subject: Re: My new Citroen ZX 16V Posted: Wed Dec 30, 2009 10:46 pm |
ooooooooooooooo lots of shiney bits in bobs
Post subject: Re: Citroen ZX TCT Posted: Sun Mar 07, 2010 2:38 pm |
I have swapped the radiator and intercooler, needs a bit of modification but those are only minor. Swapped the XM 2.1TD radiator for a Xantia 1.8i with airco one and the XM intercooler for the one purchased some time ago. The new radiator fits 100x better than the XM one. Lower, smaller and thinner(and much cleaner:P Halfway the modification Final assembly The connection between turbo and intercooler needs some extra work. I made an error when I was "designing" the connection. In het past it was way to full near the dynamo, as you can see it is now improved a whole lot. Pretty happy about it . Old way
Post subject: Re: Citroen ZX TCT Posted: Sun Jan 23, 2011 10:37 pm |
Many things happened with the car, but the most important thing is that the engine is out. Have made a new plan to get it back on the road and bought some very nice parts. A flow designed manifold, TD04 turbo and a VEMS ECU I also have: Alcon clutch OMP pressure plate 440cc injectors 1.9gti lightweight block(new liners + pistons) and flowed head ARP headstuds Modified S16/RFY crankshaft
dugy cam
Post subject: Re: Citroen ZX TCT Posted: Thu Mar 17, 2011 7:56 pm |
serious all that hard work in the car is gone.chee wizzz what happened
Post subject: Re: Citroen ZX TCT Posted: Tue Jun 14, 2011 7:29 pm |
The 1.9 GTI does not have oilspray bars. The pistons really could use some oil cooling, so i ended up buying a MI16 block. It has been stripped, so finally I can start building up the engine. Keeping power steering will be a bit difficult as the mi16 has the pas pump above the gearbox, that place has been taken by the turbo. The bracket as used on the 1.9 gti engine or the RFY engine does not fit. So I'm thinking about an electrical pump.
