It is currently Tue Apr 15, 2025 6:10 am
 Page 3 of 4 [ 55 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: [mrc] ZX 16V from Poland
PostPosted: Wed May 21, 2014 8:18 am
Back in March I drove my car to the tinsmith / painter and there is performed complete overhaul of the bodywork, chassis and profiles conservation and some painting. After careful inspection, I decided that I will changed thresholds, if necessary repaired floor and all other corroded areas.
The work was started by exchange thresholds, new one with a thickness of 0.8. Prior to founding were electro-galvanized. Rusty pieces around the drains have been cut and welded new plates, the same like the closed sections of the front, wheel arches and a place to lift the car. Sheets were covered with wash primer.
Auto at the moment is already prepared for painting and maintenance. Disassembled the fuel tank and fuel, brake lines under the car.
/ Marcin
Citroen ZX 16V RFT '96
PostPosted: Thu May 22, 2014 3:18 pm
hi
bodywork completed. the car is being prepared for painting.
changed the left front fender.
thresholds are already protected by an epoxy primer.
and at the end of the right rear fender, epoxy putty and a fiber and finishing.
/ Marcin
PostPosted: Wed May 28, 2014 12:44 pm
The work goes slowly but forward. The car has to be ready next week.
Several new images below. The front fender is already prepared for painting. Rear fenders, thresholds, recesses are at this moment prepared under the spray putty. Painting work is to be completed this week.
/ Marcin
PostPosted: Fri May 30, 2014 6:40 pm
That is going to be one pristine Zx16v when you're finished. I applaud you as many would have not took on that amount of work.
PostPosted: Thu Jun 05, 2014 2:52 pm
great that someone else appreciates these cars and see the sense of taking care of it.
paiting:
/ Marcin
PostPosted: Thu Jun 05, 2014 4:58 pm
All the hard work will be well worth it in the end. There's some great pics you've took too.
PostPosted: Fri Jun 06, 2014 3:34 pm
chassis, wheel arches and closed profiles have been already conserved. now bumpers and moldings are going to be fitted. the car is not polish yet.
fuel tank, gas and wires under the car have been fitted. after a few weeks engine started without any problem.
/ Marcin
PostPosted: Wed Jun 11, 2014 12:10 am
Nice work :)
Were the treshholds custom made or can you just order them in Poland?
PostPosted: Wed Jun 11, 2014 11:28 am
I have ordered them from specialized manufacturer but they are dedicated for standard ZX which means that they need some modification.
/ Marcin
PostPosted: Fri Jun 13, 2014 3:36 pm
I received the car. I'm happy, summarizing metalwork done in a much wider range than I expected.
Before me now a lot of work: soundproofing, interior, installation of strips. I miss cufflinks threshold strips. If anyone has a proven replacement please let me know.
/ Marcin
PostPosted: Tue Jun 24, 2014 4:07 pm
The white clips to hold the sideskirts to the treshholds?
95 637 052 -> still available at the dealer.
PostPosted: Thu Jun 26, 2014 5:10 pm
Some time ago we had been celebrating because ZX had eighteenth birthday. He pulled out the tape 1st of June 1996.
The long weekend was very busy. I took care of the interior of the car. At the beginning I put new cables for additional equipment and the old wires have been holded in brackets.
I have laundered the carpet and after that prepared new soundproofing. I bought dedicated material which here is called poroso and cut it by design. Please see pictures.
/ Marcin
PostPosted: Thu Jun 26, 2014 5:50 pm
You can see effects of chassis conservation.
The next stage is the installation of the wheel arches. Front are original + replacements, rear wheel arches comes from Peugeot 306.
Partially I have already mount a side moldings.
/ Marcin
PostPosted: Fri Jul 11, 2014 3:41 pm
Hi there. I have some detaling to do: side skirts, badges, adjust headlights, fog lights. Paint was already polished. Some photos below. Have a nice viewing.
/ Marcin
PostPosted: Sun Aug 03, 2014 4:56 pm
sill panels look good, where did they come from an how much?
Users browsing this forum: No registered users and 22 guests
