It is currently Thu May 15, 2025 4:02 pm
 Page 4 of 4 [ 59 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: My 16V
PostPosted: Sun Jun 26, 2011 7:18 pm
I am getting close to start up, but i have some trouble with the electrical. First i have dismantled a Defa warm up unit. This has been connected trough several wires. I have some bad or wrong connections that i need to sort out. I post some pic from the wires that goes out from the ignition switch. I seem to have one wire too many ?
I also wonder of anyone know what kind of relays that are sitting behind the steering wheel. I do not have any book that explains. I am just courios to know, se pictures.
The car also have a factory alarm. Anyone know if this unit can be dismantled?
eagle
PostPosted: Mon Jun 27, 2011 7:55 pm
Check wink
PostPosted: Mon Jun 27, 2011 10:14 pm
Hello,
Thanks a lot for your help.
eagle
PostPosted: Mon Aug 15, 2011 9:50 pm
You mean this whit canister box???
That belang here
Right under the abs pump.
PostPosted: Sun Oct 23, 2011 11:21 pm
Hello,
Its been a while since last time. Dont know why but it seems like i am constantly running out of time !!! Well to be honest i been doing some other priorities, but the ZX is far from forgotten. I still have some more work to be done in the front, but I have also started at the rear of the car, its time to get the car dropped a little and i have pulled the axel out and i will be going over the brakelines, calipers and bushings as well. The project is coming on nicely and a bit slow.
[/iImage
mg]Image
[imgImage
eagle
PostPosted: Mon Oct 24, 2011 9:25 am
Good luck whit the rear axel. Most of the time its a hel of a job. I realy
Like your car and your project wink
PostPosted: Mon Oct 24, 2011 5:44 pm
Fantastic project , keep up the great work
PostPosted: Tue Oct 25, 2011 11:08 pm
Thanks for your nice replies. I know that the rear axle can be a pain in the ass, but i will give it a try. I have a back up plan if it fails. Learning by walking.....
eagle
PostPosted: Sun Oct 30, 2011 9:01 pm
how much you droping it by
PostPosted: Sun Oct 30, 2011 10:58 pm
I am not sure actually, i have a 40mm lowering in front and was thinking 25-30mm.
eagle
PostPosted: Fri Aug 03, 2012 12:43 am
Well, finally some progress. I dismantled the axle, not a very pleasent job by the way. The tube on one side was completly shot, i then decided to order a rebuild one, got it from UK. Meanwhile i have had the gas tank out and have undercoated the body, also had to weld a whole as the jack has been used wrong. I work on the car when i have time to do so, to many other projects. I am now welding on my better half Saxo Vts, dident now they rust !!
[img][IMG]http://i1128.photobucket.com/albums/m499/eagle59/SAM_1490.jpg[/img]ImageImage[/img]
eagle
PostPosted: Fri Aug 03, 2012 12:46 am
[imgImage][/img]
eagle
PostPosted: Fri Aug 03, 2012 8:36 pm
cracking project eagle love the workshop keep up the good work! :lol:
PostPosted: Fri Aug 03, 2012 9:17 pm
That really is great work , keep the updates coming .
Users browsing this forum: No registered users and 30 guests
