It is currently Tue Dec 03, 2024 11:44 am
edsonmassao
Post subject: Some minor mods ^^ Posted: Sun Feb 18, 2007 5:06 pm |
Joined: Mon Oct 23, 2006 11:17 pm Posts: 193 Location: sao paulo - Brazil
ZX-Cruiser
Post subject: Posted: Sun Feb 18, 2007 6:07 pm |
Nice
edsonmassao
Post subject: Posted: Sun Feb 18, 2007 9:47 pm |
ZX-Cruiser
Post subject: Posted: Sun Feb 18, 2007 10:34 pm |
It looks smaller than your filter.
edsonmassao
Post subject: Posted: Sun Feb 18, 2007 11:23 pm |
ZX-Cruiser wrote: It looks smaller than your filter.
yes yes!
other thing that I noticed is that engine temp is a little bit higher than before...the air filter is catching hot air from the engine bay...
but the car accelerates very well
you using the same system, Cruiser?
_________________ Citroën ZX 2.0 16V Dakar spec CarDomain site Special Cars site
ZX-Cruiser
Post subject: Posted: Mon Feb 19, 2007 9:23 pm |
My filter is on the same spot, but it has an heatshield, it only pics up air from the bottom of it
edsonmassao
Post subject: Posted: Mon Feb 19, 2007 9:46 pm |
ZX-Cruiser wrote: My filter is on the same spot, but it has an heatshield, it only pics up air from the bottom of it
heatshield is the secret
this one:
or this one?
I was thinking in buy the second model...
ZX-Cruiser
Post subject: Posted: Mon Feb 19, 2007 10:15 pm |
Green Twister:
edsonmassao
Post subject: Posted: Mon Feb 19, 2007 10:55 pm |
yeah! I was wathing in the www.zx16v.net page! very good!
but you don´t have problem in the filter catch something because it´s installed too near to the floor?
the weather here sometimes is very wet, so it´s dangerous to catch some water in the admission
ZX-Cruiser
Post subject: Posted: Tue Feb 20, 2007 6:51 pm |
Here too, works just fine
edsonmassao
Post subject: Posted: Thu Feb 22, 2007 2:20 am |
Max16V
Post subject: Posted: Thu Feb 22, 2007 9:08 am |
Joined: Thu Jan 11, 2007 8:30 am Posts: 38 Location: Malaysia
Mates,
I have used the open pod filter in my first ZX 16V and found it to be very inefficient if the weather was hot. Another danger to this open filter arrangement is the possibility of sucking up water when driving through puddles of water.
After comparing the open pod filter vs standard intake system, i find that the standard system is more efficient and the safest setup available.
In order to make the best out of the standard intake system, i have ordered a drop in green cotton air filter for better power and torque. Anybody here has used it before?
ZX Cruiser,
How does your green twister perform vs the standard intake system?
_________________ With Rgds,
Max16V
1995 ZX 16V
ZX-Cruiser
Post subject: Posted: Thu Feb 22, 2007 10:47 pm |
I don't really know, I have it for years now. I can remember it didnt make it go slower.
edsonmassao wrote: what do you think if we put the filter in this local?
It might catch a lot of small debris which is coming from the wheel and gets past the plastic cover..
edsonmassao
Post subject: Posted: Wed Mar 14, 2007 2:58 pm |
hummm, some news
after the installation of the conic air filter and the modded exhaust I put my car in the same dynamometer that I made the initial measure...
I will put the graphics later, I need to scanner then
I can tell that with the large exhaust and the conic air filter I have lost a bit of torque, I have gained 6 hp and now I have not a cold air intake but a hot air intake
tip: beware with the exhaust with you put in you car, you can easily lost than gain something...
graphics coming soon
Max16V
Post subject: Posted: Thu Mar 15, 2007 2:47 am |
Mate,
Its best to stick to 2.25 inch pipe, a big centre resonator (should be bigger than original) and a good rear muffler (devil, remus)
The best bet with custom systems would be to go for a slightly larger dimension than the original system. In this way, the back pressure can be reduced and you can get a bit more power and torque with this setup.
What you guys think about this?
Max16V
1995 ZX 16V
