couple of things on my mind now to restore...
To date, changes/replacement made:
- replaced 1 faulty ACAV
- replaced alternator, belt, battery & condenser
- replaced gear knob
Comfort/Feel good phase
- upgrade to bigger brakes (ie gti-6 brakes)
- redo & replace undercarriage items (ie lower arms, bushes, ball joints, suspension, rear axle)
- replace "bubbled" dashboard (common in all zx-es in Msia) due to hot weather. Exception, dashboard with red lining are not prone to this issue...curious on the quality difference
- replace cable speedometer with "electronic" meter. Current cable type meter, the needles do judder or works like vibration movement
- relook into wiring & fix where faulty
- consider split fire ignition coils (
any feedback on this???). found it
http://www.europerformance.co.uk/pages/ ... ct=3672257Aesthetic phase
- new 16"/17" rims (Gotta import and Msia rather limited choices of perfect fit rims. prefer not to use spacer)
- projector lamps???
- sebring oval tip backbox or back to ori (currently on sebring round tip backbox)
- new coat of paint
Guess that's what i have in mind currently. How soon can it starts largely dependent on budget available
