It is currently Sun May 18, 2025 6:59 am
 Page 1 of 1 [ 8 posts ]
 Post subject: car not pulling right?
PostPosted: Fri May 30, 2008 1:30 am
just a wee question i think its the diaphrams that arint wrking but might be wrong.
wen im in 3 4 5 even 2 it seem to take ages to rev from 3000rpm to about 4000rpm any ideas wats wrong if not the diaphrams
PostPosted: Fri May 30, 2008 2:47 pm
Checking the diaphrams is easy. Start the car and let it idle. Open the hood en let it rev, you should see the the diaphrams open up the valves in the intake.
Be sure to check that first. If the diaphrams are working, check your ECU for errors. You know if there is an error when the ECU symbol stays lit for about 7 seconds after you started the car.
To read the ECU errors, check the guide at www.zx16v.net
PostPosted: Fri May 30, 2008 6:13 pm
good stuff good stuff.will try a little fiddling.it cums and goes so sumthing is faultly
PostPosted: Sat Jul 12, 2008 1:39 am
just to say i was the diaprams got new ones 39 bucks each well worth it the beasts back up to power
PostPosted: Sun Jul 13, 2008 2:13 am
i don't understand your last post..
maybe your acav is not working properly ?
/ Marcin
Citroen ZX 16V RFT '96
PostPosted: Sun Jul 13, 2008 8:19 pm
He posted that he fixed his ACAV and it's running properly now 8)
PostPosted: Sun Jul 13, 2008 10:37 pm
:) ok thanks, now it sounds easier
/ Marcin
PostPosted: Tue Jul 15, 2008 3:27 pm
sory mate iam rubbish at writing/spelling so i can easily confuse peolpe :D
