It is currently Sun Mar 02, 2025 7:14 am
 Page 3 of 4 [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Dec 18, 2008 7:40 pm
hahaha all takes time n it all hard to find time u will get ther in the end it wat i say to myself one day i will get ther looking good though n clean
 Post subject: Re: My new Citroen ZX 16V
PostPosted: Sat May 09, 2009 7:43 pm
Time for a update!
After my daily 16V died on me, I temporarily had a Nissan Sunny to my disposal. But being a complete 16V addict, I bought myself another one :roll:
It was really cheap, but there had to be done quite some work to get this car back in to good condition...and just for fun I lowered it a bit.
From the top of my head.
-Rear axle replaced
-1 coil
-2 rimms+tyres
-dampers incl new topmounts etc
-H&R lowering springs
-replaced dash
-replaced steering wheel
-exhaust from manifold to end muffler
-rear discs/pads + calipers + handbrakecables
-radiator
-Complete ACAV except for manifold
The result:
Car is lowered front + rear about 2cm, it's hardly noticeable looking at the photo though.
But this topic was about my turbo project!
I created a exhaust form turbo to the end and modified the wiring loom. It is supposed to be driveable at the end of july.
Couple of pics.
I don't have a endtip, so just used a 1 meter pipe as reference ;)
PostPosted: Tue May 19, 2009 9:58 am
It is the red one which died?
If it is, too bas you'ne not living in France! I'm looking for a Red right door, but I can't find one...
Nice work for the other one!
It's seems that there's a lot of 16V in Holland, I am wrong?
Got a ZX 16V ACAV, and I'm lovin' it!
PostPosted: Fri May 22, 2009 7:35 pm
seeks better :P
PostPosted: Fri May 22, 2009 8:23 pm
I'm only searching on Ebay and leboncoin but everytime the car is sold in one piece... If you find some, tell me!
PostPosted: Tue Aug 18, 2009 9:00 pm
It also has a new MOT and is back on the streets again :D
Modification list so far:
XU10J2TE
Garret T3(Saab)
QSP piston BOV
Group N engine mount set
Spal ventilator
XM rad + intercooler + coolant reservoir
XU10J4 oil heat exchanger
Powersprint catalytic convertor, Simons pipes and end muffler with Volvo 850 T5 tailpipe(all custom made), manifold made by someone else though
Xsara VTS 283mm brake conversion
Koni yeollw shocks with H&R springs
Phase2 alloys
Batterie in the boot
PostPosted: Fri Dec 25, 2009 5:11 pm
After some electrical problems, which prevented full boost, the car drives pretty well and even at orignal boost feels pretty quick. Compared to a 180hp RFS ZX engine it pulls already better from 140 tot 175. I have bought serveral upgrade parts which still have to be installed.
When I have upgraded the intercooler, I'm going to up the boost to about 0,95bar, hopefully I will hit the 190+ HP.
The biggest news however...
I will be stripping and complete rebuilding 2 ZX 16V's together with another forum member. One with the RFS engine build up with group A specs and one turbo one, I however don't have decided if I will keep using the tct engine or are going to build a RFY one...
PostPosted: Sun Dec 27, 2009 10:15 pm
I drive in it. Its a realy nice car. and i had a lot of fun to drive it. When the ingene pas the 3000 rpm the car accelerates realy fast :twisted: now up to 1 bar boost :twisted: And the whole car overhaul :lol:
PostPosted: Wed Dec 30, 2009 10:46 pm
ooooooooooooooo lots of shiney bits in bobs
 Post subject: Re: Citroen ZX TCT
PostPosted: Sat Jan 30, 2010 12:06 am
Swapped the RGY(145hp) ECU for the RGX(150hp). It makes a big difference! You can not feel any difference in max hp, but the engine is much much smoother and stronger in the 2500-4000 rpm range. First gear is a bit useless at the moment :roll:
PostPosted: Sun Mar 07, 2010 2:38 pm
I have swapped the radiator and intercooler, needs a bit of modification but those are only minor. Swapped the XM 2.1TD radiator for a Xantia 1.8i with airco one and the XM intercooler for the one purchased some time ago. The new radiator fits 100x better than the XM one.
Lower, smaller and thinner(and much cleaner:P
Halfway the modification
Final assembly :) The connection between turbo and intercooler needs some extra work. I made an error when I was "designing" the connection. In het past it was way to full near the dynamo, as you can see it is now improved a whole lot. Pretty happy about it ;).
Old way
PostPosted: Sun Jan 23, 2011 10:37 pm
Many things happened with the car, but the most important thing is that the engine is out. Have made a new plan to get it back on the road and bought some very nice parts.
A flow designed manifold, TD04 turbo and a VEMS ECU
I also have:
Alcon clutch
OMP pressure plate
440cc injectors
1.9gti lightweight block(new liners + pistons) and flowed head
ARP headstuds
Modified S16/RFY crankshaft
PostPosted: Tue Mar 15, 2011 1:23 am
http://www.youtube.com/watch?v=9B7G1NQu8B8
The car has been scrapped due to accident damage. This was the very final drive with this car and only at 0,5bar boost...
PostPosted: Thu Mar 17, 2011 7:56 pm
serious all that hard work in the car is gone.chee wizzz what happened sad
PostPosted: Tue Jun 14, 2011 7:29 pm
The 1.9 GTI does not have oilspray bars. The pistons really could use some oil cooling, so i ended up buying a MI16 block.
It has been stripped, so finally I can start building up the engine. Keeping power steering will be a bit difficult as the mi16 has the pas pump above the gearbox, that place has been taken by the turbo. The bracket as used on the 1.9 gti engine or the RFY engine does not fit.
So I'm thinking about an electrical pump.
Users browsing this forum: No registered users and 16 guests
