It is currently Sun Apr 20, 2025 5:27 am
 Page 1 of 1 [ 9 posts ]
 Post subject: Leaking rear quarter lights
PostPosted: Thu Nov 18, 2010 10:08 pm
Having a bit of a nightmare with water leaking through the rear opening quarter lights of the ZX , the window rubbers are soft and supple and not perished or dry , the water seems to be building up and getting through the seal , has anyone else encountered this on there zx , please help , Mark
 Post subject: Re: Leaking rear quarter lights
PostPosted: Thu Nov 18, 2010 11:05 pm
I've never heard of it. maybe if you post some pics!? i know the Zx inside out
PostPosted: Fri Nov 19, 2010 7:54 am
Sorry can't get any pics posted but the leak is just behind the door pillar on the bottom of the seal about 75mm in from the bottom of the window , I know it sounds silly but the water seems to be getting in at exactly the same place on both sides ! Tried pushing the rubber down between the glass when shut but it's not really done much , my friend who used to work for Citroën is puzzled too , Mark
PostPosted: Sat Nov 20, 2010 5:58 pm
I have the same problem, but only at the left side. Don't know where it is coming from either.
PostPosted: Sat Nov 20, 2010 6:40 pm
Spoke to my friend today who is an ex Citroën mechanic and he said an option was to tap the metalwork that the rubber seal pushes onto with a piece of wood and a hammer , I know it sounds brutal but he says this should solve it ? Did think of a rubber seal of a pug 306 but there not available anymore like the Zx ones aarrgh ! Will keep updating on the progress , Mark
PostPosted: Wed Dec 08, 2010 9:51 pm
so didthis trick work then i had this problem on my ax but it was just a wee tap on the sead and to the meatal uder it in all goood so far
PostPosted: Thu Dec 09, 2010 9:17 am
I've not tried this method yet but hopefully it might work , just waiting for my mechanic mate to have a look at the heater as it blows warm through the fascia vents but cold to the screen , he says it's a common problem on the Zx , will keep you updated , how's the weather up there Dougy ! I hope your well wrapped up if your working on the car , Mark
PostPosted: Thu Dec 09, 2010 2:01 pm
Was going to say about using a xsara coupe seal to see if that works. But you may have solved it.
PostPosted: Thu Dec 09, 2010 2:20 pm
Cheers Carl I will bear that in mind , Mark
