It is currently Thu Dec 05, 2024 1:42 am
 Page 3 of 8 [ 106 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 8  Next
 Post subject: Re: Black Citroen ZX 2.0 16v 1992 from Poland.
PostPosted: Sat Jan 22, 2011 8:27 pm
Is it a bit accurate? You know you're way with electronics :idea:
What did you use as input signal?
PostPosted: Sat Jan 22, 2011 8:41 pm
Wow!! dit you have technical details about it. 1 want to now how that thing the fuel consumption knows?????
PostPosted: Sat Jan 22, 2011 8:49 pm
speed is exacly the same like GPS (from original VSS - vehicle speed sensor, rescaled)
fuel consumption is +/- 0.3l for 50liters (it's counting impulses from injectors, accuracy is 0.1ms per cycle)
it's home made, maybe i'll do some for trade, dont know ;)
PostPosted: Sat Jan 22, 2011 8:58 pm
You only count the pulses? Inject time vary with rpm/speed/load does your mod use the inject time(it must be or else it can not be accurate)?
PostPosted: Sat Jan 22, 2011 9:05 pm
Microcontroller counts width of pulses with 0.1ms accuracy. You need to know also a injector const (about 0.003 l/s) to calculate real-time and avg. fuel cons.
Take a look at pct:
900 rpm http://img708.imageshack.us/i/900rpm.jpg/
2500rpm http://img502.imageshack.us/i/2500rpm.jpg/
3500rpm http://img413.imageshack.us/i/3500rpm.jpg/
PostPosted: Sat Jan 22, 2011 9:08 pm
Excellent work ugeek
PostPosted: Sun Jan 23, 2011 3:13 pm
Top work biggrin
Always wanted one of these after I saw the first version you did
PostPosted: Tue Feb 15, 2011 8:48 pm
added some new functionality to onboard computer, but still need new inspiration... have u got any ideas what else can i add to it ? :)
I'd like to start up with production of it (in few months) .. it's now universal to any car with electr. injection.
ps. my new zx wallpaper http://www.klub.citroen.triger.com.pl/i ... d82824.jpg :p
last photo is fuel tanks (i have pb and lpg in car - lpg in PL is twice chipper than pb)
PostPosted: Tue Feb 15, 2011 9:01 pm
Engine load. Maybe you can take a signal for it from the throttle position sensor, Exhaust temperature. I like your project. I think a want some of it in the futere ugeek
PostPosted: Wed Feb 16, 2011 4:10 pm
How about battery voltage + CO2 value? if possible 8-)
PostPosted: Wed Feb 16, 2011 5:04 pm
good idea! I will do it ;) thanks
PostPosted: Thu Feb 17, 2011 7:25 pm
great work! :P
what about data from lambda sensor.. air/fuel ratio in the exhaust..oxygen..
keep updating! ugeek
PostPosted: Sat Apr 09, 2011 11:22 pm
not lucky day and not my fault
PostPosted: Sun Apr 10, 2011 8:23 am
Nightmare ! That looked mint too , what's your chances of putting her back on the road , is it a re-shell , hope you get sorted
PostPosted: Sun Apr 10, 2011 1:28 pm
Looks nasty :(
