It is currently Sun May 18, 2025 10:48 am
ZX-1993
Post subject: Exhaust manifold  Posted: Fri Sep 16, 2011 3:03 pm |
Joined: Sat Dec 08, 2007 2:33 pm Posts: 43 Location: Southampton, UK
Hello, does anyone know of the best way to remove the exhaust manifold? The area around it is so tight. which way does it come out?
Basically I have a 8 branch manifold that I want to fit.
Tony
Post subject: Re: Exhaust manifold  Posted: Fri Sep 16, 2011 8:26 pm |
on the RFY it'll come out the top easily enough if you remove the top r/h engine mounting arm and tilt the engine forwards.
fitting the new manifold will be a different task though, easiest way is to drop the subframe complete, unless the manifold is in 2 parts? not seen any 8 branck manifolds, most are just 4.
ZX-1993
Post subject: Re: Exhaust manifold  Posted: Fri Sep 16, 2011 9:19 pm |
Ok cool ill do that.. Its just one piece. The manifold is off a 405 Mi16. (if I recall correctly)
Nice one
Post subject: Re: Exhaust manifold  Posted: Fri Sep 16, 2011 10:25 pm |
that wont fit in a zx, the shape is quite different
ZX-1993
Post subject: Re: Exhaust manifold  Posted: Fri Sep 16, 2011 10:57 pm |
The actual stud pattern on top is different, i was going to make a long 'washer' to clamp it up to the head. Or is it the actual physical size of the manifold?
Post subject: Re: Exhaust manifold  Posted: Sat Sep 17, 2011 8:44 am |
It's longer and the angle is different. So modifications to the downpipe are necessary.
ZX-1993
Post subject: Re: Exhaust manifold  Posted: Sat Sep 17, 2011 3:24 pm |
ah ok, I might just forget about that one then.
Post subject: Re: Exhaust manifold  Posted: Sat Sep 17, 2011 8:49 pm |
if you want a decent manifold for it get in tough with miles at pugracing, not too far from you in Fordingbridge.
Post subject: Re: Exhaust manifold  Posted: Sun Oct 02, 2011 8:51 pm |
ther is one on ebay the now pricely but ther is one so they say
