It is currently Sun May 18, 2025 3:01 am
 Page 1 of 1 [ 9 posts ]
 Post subject: Exhaust manifold
PostPosted: Fri Sep 16, 2011 3:03 pm
Hello, does anyone know of the best way to remove the exhaust manifold?
The area around it is so tight. which way does it come out?
Basically I have a 8 branch manifold that I want to fit.
Tony
 Post subject: Re: Exhaust manifold
PostPosted: Fri Sep 16, 2011 8:26 pm
on the RFY it'll come out the top easily enough if you remove the top r/h engine mounting arm and tilt the engine forwards.
fitting the new manifold will be a different task though, easiest way is to drop the subframe complete, unless the manifold is in 2 parts? not seen any 8 branck manifolds, most are just 4.
PostPosted: Fri Sep 16, 2011 9:19 pm
Ok cool ill do that..
Its just one piece.
The manifold is off a 405 Mi16. (if I recall correctly)
Nice one
PostPosted: Fri Sep 16, 2011 10:25 pm
that wont fit in a zx, the shape is quite different
PostPosted: Fri Sep 16, 2011 10:57 pm
The actual stud pattern on top is different, i was going to make a long 'washer' to clamp it up to the head.
Or is it the actual physical size of the manifold?
PostPosted: Sat Sep 17, 2011 8:44 am
It's longer and the angle is different. So modifications to the downpipe are necessary.
PostPosted: Sat Sep 17, 2011 3:24 pm
ah ok, I might just forget about that one then.
PostPosted: Sat Sep 17, 2011 8:49 pm
if you want a decent manifold for it get in tough with miles at pugracing, not too far from you in Fordingbridge.
PostPosted: Sun Oct 02, 2011 8:51 pm
ther is one on ebay the now pricely but ther is one so they say
