It is currently Sat Sep 21, 2024 5:27 am
Cromptons
Post subject: Re: Black ph1 16v (UK) Posted: Sun Apr 03, 2011 10:55 pm |
Cromptons
Post subject: Re: Black ph1 16v (UK) Posted: Fri Oct 28, 2011 8:19 pm |
A little update,
Decided finally to bite the bullet and sort out the rust issues...
Various little holes in front arches.
But worst is the non existent off side rear lifting point and the very front of the sill.
Took the off side skirt off today, does anyone know where to get the white clips what hold the top of the skirt, service box says they are discontinued but will be ringing various dealers soon.
Depressing photos to follow.
Mark I've lost your mob number.....
Post subject: Re: Black ph1 16v (UK) Posted: Fri Oct 28, 2011 8:40 pm |
I'll text you my number James when I get a minute , how's the diesel going , did you sort out the turbo
Post subject: Re: Black ph1 16v (UK) Posted: Sun Oct 30, 2011 8:59 pm |
a the jacking points pain in the arse mine was taking of a while a go never used then.im sure u get the clips of ebay im sure as i bought a fe differnt clips in that for the archs in all that.
eagle
Post subject: Re: Black ph1 16v (UK) Posted: Sun Oct 30, 2011 11:07 pm |
Joined: Thu Jan 06, 2011 8:36 pm Posts: 51 Location: Norway
I am also in need of those clips, if anyone see them for sale somehere, please give me a hint.
_________________ eagle
Post subject: Re: Black ph1 16v (UK) Posted: Sun Oct 30, 2011 11:14 pm |
And i need them to. Maybe is there a compagnie that will make them?
Cromptons
Post subject: Re: Black ph1 16v (UK) Posted: Wed Nov 09, 2011 10:46 pm |
Welding bloke has got it now. Had to remove fuel tank and front struts. Make brand new sills as no-one makes aftermarket zx sills Regarding the clips I only found one supplier and he only had 4 (which I bought). "apparently" these http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 1399wt_802 might fit, I've bought a set and will wet you know...
Post subject: Re: Black ph1 16v (UK) Posted: Fri Dec 23, 2011 1:09 pm |
Hi, re the 6 speed conversion, does the original linkage fit? I realise the gti6 gearstick and cable are needed but did you change the bar and small links over too? Also did you need to drill a hole in the bulkhead for the reverse cable or does it fit through an existing hole?
Mines going in a Xsara but should be the same as the zx as far as converting goes.
Merry Christmas, Steve.
Cromptons
Post subject: Re: Black ph1 16v (UK) Posted: Thu Feb 02, 2012 8:39 am |
The little gear linkages are the same, and yes you do need to drill a small hole.
James
Post subject: Re: Black ph1 16v (UK) Posted: Thu Feb 02, 2012 3:00 pm |
The box is going in this!!! only because I can't find a ZX kitcar mind!! Where did you put the hole bud, bottom of the stick or in the bulkhead?? Cheers Steve
Post subject: Re: Black ph1 16v (UK) Posted: Fri Feb 03, 2012 12:55 am |
Post subject: Re: Black ph1 16v (UK) Posted: Fri Feb 03, 2012 2:38 pm |
welshpug wrote: If I'm right it came from Scotland via a motorsport breaker in the north and was probably silver?? I want by the way!!!
Post subject: Re: Black ph1 16v (UK) Posted: Sat Feb 04, 2012 12:24 am |
dont know but its down near Bridgend with some ex btcc exotica from the 90's!
Post subject: Re: Black ph1 16v (UK) Posted: Sun Feb 12, 2012 7:16 pm |
one day i will get mine done and all finished not any time soon but one day hahahahaha
