It is currently Sat May 17, 2025 6:04 pm
my911gt2
Post subject: Re: MY FIRST 16V  Posted: Thu Dec 15, 2011 2:19 pm |
Joined: Sat Aug 02, 2008 5:05 pm Posts: 82 Location: Sussex England
big problem i have at the moment is that the air filters fit the underside of the bonnet ,
so i have to make a bonnet vent to fit
any thoughts on design , it needs to be 69CM long as i want it to be equil on each side
i have attached a photo of what i have neen thinking
this is a fake vent but i like the design so i may make one from 1.2mm sheet
Attachments: |
Post subject: Re: MY FIRST 16V  Posted: Thu Dec 15, 2011 4:22 pm |
please dont! just get a proper inlet manifold!
my911gt2
Post subject: Re: MY FIRST 16V  Posted: Thu Dec 15, 2011 5:00 pm |
i do have a proper inlet manifold.
it is from QEP and made by Longman's
its the correct one
Post subject: Re: MY FIRST 16V  Posted: Thu Dec 15, 2011 8:08 pm |
I know, its the same that jenvey and omex sell its a shoddy attempt at an "off the shelf fits all" thing, a proper manifold will mean no crap looking bonnet vents.
get one with more of a curve and slightly longer and you will make more power.
my911gt2
Post subject: Re: MY FIRST 16V  Posted: Thu Dec 15, 2011 9:02 pm |
im not going to just throw the one i have away ,
also with a vent i can set up a ram air system ,
i also fail to see how a longer manifold will give me more power,
a long track manifold will give you more torque but a slower reving engine
a short track gives a faster reving engine ,
Post subject: Re: MY FIRST 16V  Posted: Thu Dec 15, 2011 11:51 pm |
longer tract wont make it rev less.
its all about pulse tuning, have spoken to Sandy brown quite a bit about it and he builds all his race eng9ines with long tracts.
my911gt2
Post subject: Re: MY FIRST 16V  Posted: Fri Dec 16, 2011 2:08 pm |
ok so i have paid £200 for the mainfold so i throw this in the big and buy a new one for what ?
so its going to cost around what £500
what will i gain 3-4BHP >
i will stick with what i have and use a ram air system and by doing this i can set up a head shield so the hot air from the rad does not get sucked into the engine so i will have some gains from using cold air ,
i just dont see the point , yes its would be nice to not have to put a vent in but it would mean that the air filters would also sit on the rad , and with engine movment e,c,t
Post subject: Re: MY FIRST 16V  Posted: Fri Dec 16, 2011 4:12 pm |
a lot more than 3-4bhp, its about the are under the peak.
Post subject: Re: MY FIRST 16V  Posted: Fri Dec 16, 2011 5:01 pm |
RAMAIR is only effective at higher speeds. In general: Longer inlet runners usually help with low rpm torque while sacrificing peak hp at high rpm. However as welshpug says it's all about "the pulsation of the inlet air" the right (it will always be a compromise) length of runners depends on the block itself (valve timing, compression, exhaust manifold etc) and the rpm range you will be at most of the times. I think that switching to longer runners wil give you a better usuable powerband and it will be well worth the money tot get another inlet manifold.
my911gt2
Post subject: Re: MY FIRST 16V  Posted: Fri Feb 17, 2012 9:10 pm |
~CAR HAS NOW BEEN SCRAPPED
ALL PARTS AND SPARES GONE
MOVED TO NEW ZEALAND
NO MORE ZX FOR ME
Post subject: Re: MY FIRST 16V  Posted: Fri Feb 17, 2012 10:39 pm |
should have said earlier, I'm after a shell!!
Post subject: Re: MY FIRST 16V  Posted: Sat Feb 18, 2012 9:11 pm |
The very best of luck with the move . Hope some of the parts went to a good home Mark
my911gt2
Post subject: Re: MY FIRST 16V  Posted: Sun Feb 19, 2012 8:50 am |
all parts went to the scrap yard ,
nothing was sold ,
people didnt seem to like what i had done to the ZX so i thought no one would want anything from it ,
you guys only seem to like IBS and not Carbs for a start ,
nothing i had seemed any good so i thought fuck it
