It is currently Mon Dec 02, 2024 1:19 pm
Post subject: do all 306 suspesion fix zx ones Posted: Sun Oct 02, 2011 9:16 pm |
just as the topic title says just out of intrest as u get more choice and better quality
Post subject: Re: do all 306 suspesion fix zx ones Posted: Mon Oct 03, 2011 6:02 pm |
I dont get what you are asking?
Post subject: Re: do all 306 suspesion fix zx ones Posted: Mon Oct 03, 2011 8:03 pm |
as in dampers, struts thats all im sure they do but thought i would ask for the crack
Post subject: Re: do all 306 suspesion fix zx ones Posted: Mon Oct 03, 2011 9:47 pm |
I dont think stuts will fit. Because the 306 is wider
Post subject: Re: do all 306 suspesion fix zx ones Posted: Tue Oct 04, 2011 11:24 pm |
still don't understand you crack?! are you on it?? 306 is not wider, It is exactly the same floorpan as the ZX.
Post subject: Re: do all 306 suspesion fix zx ones Posted: Wed Oct 05, 2011 8:45 am |
The struts(parts) are the same, but if you measure the strut distance between a 306 and a ZX. The 306 is 104cm where the ZX is 102cm. I can't remember the actual numbers. Strut towers are not the same.
Post subject: Re: do all 306 suspesion fix zx ones Posted: Wed Oct 05, 2011 1:55 pm |
Is the zx not the same as the 309? sure there are a few differences between the 306 and the zx, rear beam ect???
Post subject: Re: do all 306 suspesion fix zx ones Posted: Wed Oct 05, 2011 6:23 pm |
no, thats the 205, mostly.
zx rear beam is the same as a 306, as in they will bolt on and the parts will swap, specs are quite different though, 21mm rear torsion bars on the zx, 20mm on the 306, plus zero rear toe in on the zx, 3.5 degrees iirc on the 306.
distance between the top mounts would explain why the ZX has more camber on the front, but the parts are all interchangeable, track is the same
Post subject: Re: do all 306 suspesion fix zx ones Posted: Thu Mar 01, 2012 10:12 pm |
all i meant was the front supension as in if i was going to buy a suspension kit that inclueded coilovers could i buy 306 ones just was checking wasint 100% sure
