It is currently Fri Feb 28, 2025 2:35 am
 Page 1 of 1 [ 12 posts ]
 Post subject: Code sistem on my Citroen ZX 1.8i
PostPosted: Sat Mar 31, 2012 1:19 pm
Hi, sorry the article that the forum on the Citroen ZX 1.8i model. but I have a problem with the code. Previous owner lost a code and the machine can no longer starting because there is no spark and the pump is shut down, most likely that the jets do not work. I am interested in how to disable the device so that everything works as should be. Just want to disable the source machine. Maybe someone knows how to do it?
PS I am a Latvian and translated with the help of google, so it may happen that one word is wrong.
 Post subject: Re: Code sistem on my Citroen ZX 1.8i
PostPosted: Sat Mar 31, 2012 7:30 pm
I tought that only the dealer can restet the code confused
PostPosted: Sun Apr 01, 2012 7:52 am
Well, maybe someone else can comment on it?
Maybe someone can put circuits of the system is connected to the machine?
PostPosted: Sun Apr 01, 2012 4:54 pm
If you are lucky an engine mapper might be able to remove the code for you.
One of my 16V's did not need the code when the battery is disconnected while the ignition is switched on and reconnected after a minute or so. The led on the keypad will turn green, so it is easy to verify. If you get a green led then disconnect the battery and remove the keypad.
PostPosted: Fri Apr 06, 2012 8:22 pm
How many times can enter the wrong code?
PostPosted: Fri Apr 06, 2012 9:05 pm
After three wrongly entered codes, it will not be possible to enter the correct one for 30 minutes.
PostPosted: Fri Apr 06, 2012 11:03 pm
Well the obvious
Then every 30 minutes, again i can try to guess the password?
PostPosted: Fri Apr 06, 2012 11:06 pm
Yes. Only that take some time
PostPosted: Sat Apr 07, 2012 12:45 pm
I wanted to ask. You surely know that what they do on the keyboard. I have signs in each case with a number. And did not somebody please explain what each button does it? And by the lights and paskaidrojies please.
And when I run this code? I turn on the ignition when the lights came on all the panel and then enter the code and then i can start?
Picture: Image
PostPosted: Sat Apr 07, 2012 3:53 pm
Dont use the red market buttons. They are onley to chances the code. Onley turn on the ignition and type the code. When the green lamp is on. You can start
PostPosted: Sat Apr 07, 2012 4:02 pm
4 is burning red light.
5 green light is lit.
When entering the code then both must form the green?
And thanks for the good response.
PostPosted: Sat Apr 07, 2012 7:50 pm
No. Nr 5 starts to burn
