It is currently Fri Apr 04, 2025 3:13 pm
Post subject: Re: Citroen ZX 16V  Posted: Wed Jun 20, 2012 10:49 pm |
I have an alloy sump of the 2.1TD engine and wanted to use it on my block, but it doesn't fit over the oilpump. I thought the 2.1TD and the TCT used the same oilpump, but that obviously isn't the case. As I didn't want to clean a metal sump, I decided to put the head on.   My 1mm skimmed head.  Lot's of assembly lube to bed the DKZ camshaft in.   I only put the belt on, so I can rotate the engine. I would like to dial the DKZ cam in per exact specs, but unfortunately I haven't come across them...
Post subject: Re: Citroen ZX 16V  Posted: Fri Jan 04, 2013 3:37 pm |
Crap, after 280.000+km cilinder three only has 5 bars of compression. After searching for a temporary ZX and finding nothing to my liking, I have opted to buy something a bit more comfortable:
Post subject: Re: Citroen ZX 16V  Posted: Fri Jan 04, 2013 8:56 pm |
Post subject: Re: Citroen ZX 16V  Posted: Sat Jan 05, 2013 12:00 am |
Unfortunately not. It had to be something that has low ownerships cost and runs as economical as possible.
Post subject: Re: Citroen ZX 16V  Posted: Sat Jan 05, 2013 12:05 am |
Theres certainly lots of love going into that engine , very comfy car the Bx , is it a diesel one by any chance . I've had a few Bx16v's , a quick car but they can't touch the Zx16v for handling Mark
Post subject: Re: Citroen ZX 16V  Posted: Sat Jan 05, 2013 12:27 am |
No, it's a 1.4i Deauville. It has a steering wheel, brakes and that's it :)
Post subject: Re: Citroen ZX 16V  Posted: Sat Jan 05, 2013 12:36 am |
That will just waft along nicely in total comfort , speed bumps won't even effect it Mark
Post subject: Re: Citroen ZX 16V  Posted: Sat Jan 05, 2013 12:23 pm |
you seem to have a few valves missing :p
Post subject: Re: Citroen ZX 16V  Posted: Mon Apr 15, 2013 9:15 pm |
Finally the temperatures are getting higher, so time to tinker with 16V. Only managed to get the bonnet off, as I had to reorganize the garage, but now there is at least space to get the engine out.
Post subject: Re: Citroen ZX 16V  Posted: Mon Apr 29, 2013 11:17 pm |
Today I removed the head. The lack of compression at cilinder three had no other reason than simpy wear as can be expected with an 280.000km + engine.  With the head off I could then fit a dummy head and trial fit my turbo setup...  It looks pretty bulky, but if it fitted in a 205 it should surely fit in an ZX right?  Let's take a closer look:   Fuck  It isn't even close to fitting. How the hell can a 205 have more drivebay room than a significant larger ZX
Post subject: Re: Citroen ZX 16V  Posted: Tue Apr 30, 2013 9:32 pm |
Well if a 3.0 V6 fits , you would think the 2.0 8v Tct would be no problem .
Post subject: Re: Citroen ZX 16V  Posted: Tue May 21, 2013 9:50 pm |
205 is certainly not bigger, but it is a different shape.
Post subject: Re: Citroen ZX 16V  Posted: Tue Jun 18, 2013 2:03 pm |
I don't know what I want to do with the ZX 16V, either build my own turbo manifold and continue the turbo build or just put an RFS in it and drive it around. I was a bit tired of the BX, too long, too slow, too big of a turning circle, no powersteering so I bought a Saxo 1.6 8V VTR. For the MOT I needed to replace the steeringhouse gaitor, easy fix and I needed to fix the cat/mid muffler connection. Since the flange was pretty much gone, I just welded the two pieces together. Still leaking off course, I did not notice the downpip flange was pretty fucked too :annoyed: Bought myself a Raceland 4-2-1 manifold for less than a new downpipe would cost me and I will have the added bonus that the engine will look as if it has more hp!
Post subject: Re: Citroen ZX 16V  Posted: Wed Jun 19, 2013 12:55 pm |
just put the rfs in on bodies
