It is currently Sat Apr 19, 2025 3:53 pm
 Page 3 of 4 [ 51 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: My Zx16V
PostPosted: Mon Oct 29, 2012 10:30 pm
new part.
mk2 goes mk3 :)
the next part is a "Fächerkrümmer" i hope the english name is manifold
PostPosted: Sun Nov 04, 2012 2:18 pm
Are you planning on remapping the original ECU with the RFS inlet manifold?
PostPosted: Sun Nov 04, 2012 9:33 pm
for the first time, yes.
bad idea?
PostPosted: Sun Nov 04, 2012 11:49 pm
No, not at all. I am actually curious about the results it will have on power and torque.
PostPosted: Mon Nov 05, 2012 8:12 pm
i hope the torque will better with this part.
the next step is a manifold and other injectors.
I talked with someone from germany, and this guy´s engine has 190 hp with some changes.
PostPosted: Tue Nov 06, 2012 9:58 am
Zx16V-1994 wrote:
new part.
mk2 goes mk3 :)
Sory, but the part that you show as is a "AnsaugbrĂĽcke" aka intake manifold
"Fächerkrümmer" is a exhaust manifold
Trust me :mrgreen:
My stock XU10J4 exhaust manifold
mod progress
the final result
should be an inspiration for you :P
I have a lot done to my engine.
PostPosted: Tue Nov 06, 2012 7:39 pm
looks good cheesygrin
sry, i had meant exhaust manifold :)
(my englisch is not the best sry )
maybe i will get someone like that :P http://www.donsilencioso.com/images/upl ... tor_zx.JPG
have the changes from you, something brought?
PostPosted: Wed Nov 07, 2012 1:28 pm
this exhaust mainfold look's like from the RFS engine (XU10J4RS) from mk3 - Dakar version
the RFS exhaust mainfold don't fit to the XU10J4 engine from mk1/mk2 without a exhaust wedge plate
exhaust wedge plate - "Auspuff Keilplatte"
my mod's on the head, inlet mainfold (the original ACAV inlet), original exhaust mainfold, lighter and balanced flywheel, fuel presure moved up to 3.1 bar give me 156HP with the original rpm limit from the ECU (probably 7.2K rpm).
With the rpm limit move to 8k it have 170 HP. (the engine can run to 10K rpm. but 8K is a safe solution cheesygrin )
PostPosted: Wed Nov 07, 2012 8:19 pm
yes, and maybe i´ll get this one, and i can change the exhaust wedge plate, with cnc machine´s.
170 hp is very nice :D
good job
PostPosted: Fri Dec 14, 2012 3:09 pm
update:
zx mk2 goes mk3 the next part ;)
new stuff.
PostPosted: Fri Dec 14, 2012 8:54 pm
The leather in the Zx looks great , don't forget to get some more pics after it's fitted .
PostPosted: Thu Jan 03, 2013 8:29 pm
PostPosted: Tue Feb 12, 2013 2:24 pm
PostPosted: Fri Feb 15, 2013 8:20 am
Looks good. Onley i am wundering if you realy got more power with this setup?
Users browsing this forum: No registered users and 25 guests
